PVC question
r.booser
Knoxville
Ron
I have a 85 C20 350 that I recently acquired. I noticed the PVC is not hooked up to anything currently. My understanding is the it should plug into the front of the carb (it has a edelbrock). For some stupid reason the post coming out of the carb is bent all to hell. So I guess first does this need to be hooked up? I have seen were some say yes and other say no. Also since the idiot before bent that do you have a trick in fixing it?
roving4s
America
xxxx
Pull out the pcv valves go get a spectra breather from autozone. I've got a breather on both sides of my valve cover. No leaking or oil spray anywhere. The other option is to buy a catch can. Just depends on how much money you wanna spend.
Think I paid about $9 each for the breathers, used a flathead to push it into the valve cover. And was done, even makes the engine bay look cleaner.
http://www.autozone.com/autozone/ac...r/_/N-25xhZ1z141wx?itemIdentifier=266497_0_0_
bobkyle2
Illinois
Kyle
K5 Blazer
Yes, It really should be hooked up. Can you unbend that port?
r.booser
Knoxville
Ron
I don't know, haven't tried yet. Wasn't sure if there was some secret to doing it. Otherwise I would just try to get a flat head in there and bend it back into place. Wasn't sure if a breather would be fine or not.
Stroked
Beloit, Kansas
Jared
You really need to have the PVC hooked up properly. If you can't bend it back, I think it's just a standard fitting. You should be able to unscrew it and buy a new one at your local hardware store.
Somebody here posted before about replacing those vacuum ports on carbs, i can't find the posts though. i thought it was swims350. :think:
r.booser
Knoxville
Ron
ok great, I'll just add it to my list tonight and replace it. I'll look and see if I can find that write up too.
Yah it had parts links too if I remember right
Stroked
Beloit, Kansas
Jared
My bad, I assumed it screwed in, but after looking at pictures that doesn't appear to be the case. Looks like it's pressed in.
Yah they press in and out.
bobkyle2
Illinois
Kyle
K5 Blazer
I'd just reem'er out get it looking straigt and run a piece of hose to it. Might have to put a hose clamp on it or something. It don't have to be super tight.
Post some pics if you can...
r.booser
Knoxville
Ron
will do, I should probably have it done tonight.
Swims350
Logan WV
none
I never done it before, but you do know you can run it off the back of the carb right?
there's usually a 1/4 npt plug in the back that you can unscrew and buy a nipple for it, then connect a hose, or get yourself some vacuum tees and do it that way. I'd bet you could even do manifold vac. because that front port draws vac. all the time.
r.booser
Knoxville
Ron
I had no idea, makes perfect sense though. I'll see if I can correct the previous owners stupidity first. Thanks for all the help guys. I will have more questions I'm sure regarding other issues. I have a ground hanging from the tank and the filler neck seems loose on the tank as well. Those will come after I change the distributor, upgrade ground, fix pvc and heater core this weekend.
bobkyle2
Illinois
Kyle
K5 Blazer
You can sometimes find decent looking air cleaners that have the place to hook into.
goodwrenchca
