Pulling drive train, should I remove the front clip?
Preston
Mechanicsville VA
Preston
Donor truck
i have pulled many engines in my life, but I’ve never removed the front clip to do this. Just wondering if it’s worth the trouble. May be an advantage on reinstallation because my 84 4x4 is lifted, and may keep me from falling from the truck, also could build a scaffolding around the truck, but that could be an issue as well. I will be removing the body lift too, so might be the way to go. My donor truck will be going to the Mud Bog world so I don’t think the new owner will mind it in pieces. Also I’m wondering if I could get a helper can the whole front clip come off in one piece? Thanks for your help
RoryH19
Rory
R10 Silverado SWB
When I did my LS swap on my K5 I pulled the hood and core support. I was able to loosen the fenders to take the core support out without having to completely remove.
My K5 is also lifted and I removed and installed with the trans attached.
Preston
Mechanicsville VA
Preston
Thanks for your help, I’m going to be doing the swap outside so I will try to get the two trucks close enough to pivot the hoist from one truck to the other, also will have to rebuild the transmission before the reinstall. Will give me time to de smog the motor and make a few additions, cam, headers etc. and of course clean and paint it all up.
RoryH19
Rory
R10 Silverado SWB
I was in a garage so didn't have much ceiling clearance or space between them to work with. When the donor was out I resealed everything except taking the heads off. Those gaskets were good. I tried to reinstall with the new headers on but didn't have enough space. They are even the short style. I ended up pulling them and installing from the bottom after the drivetrain was in.
Craig 85
Nashville, TN
454/TH-400/NP205
You can also just pull the core support and inner fenders. I was cleaning up the engine compartment here and changing the A/C evap core.
Preston
Mechanicsville VA
Preston
Good idea, sure beats hanging over the fenders
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I like pulling the core support, dont even have to pull the hood. Make it easier to remove the engine and trans together. I also do my work outside so while it may require extra labor its part of getting the job done for me.
4WDKC
Southern Florida
Kacy
Pull it, I did cam/heads swap on my lifted 4x4, it was a pita and hard on my back. Also if you are removing the body lift it makes more sense to pull it..both of those look fairly nice, why is one headed for mud bog?
Preston
Mechanicsville VA
Preston
I keep buying donor trucks and don’t want to part them out, I have 2 here now looking for running gear for a third one. I bought the lifted truck from a man that had started an LS swap and he changed his mind about the build. I’m not sure about using the engine that’s out of a 2005 truck, trying to use the straight front axel etc. if someone can tell me how to use the LS with the 84 transmission and transfer case economically I might change my mind. Thanks
After thought really all I need is an automatic transmission that will bolt to the LS engine and will work with a NP205 transfer case . Thanks again
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I'm thinking you'll need a 4L60 tranny to bolt to the Ls motor. Someone will correct me if I'm wrong.
Preston
Mechanicsville VA
Preston
Thanks, Doug
will my NP205 bolt to a 4L60e transmission ?
4WDKC
Southern Florida
Kacy
the th350 will bolt to it, I believe you need a spacer for the convertor possibly a convertor.
You dont need a 4l60 but most people take advantage of it becase the ecm will control the trans also
Thanks, Doug
There are adapters to do anything but some can be expensive..You can bolt a 208 to the 4l60 as I had one bolted to my 700r4.
82sbshortbed
Fuckemall!!
SE Texas
Doug
I knew someone who knew more about it would chime in. Good post 4WDKC
Preston
Mechanicsville VA
Preston
I found this 4L60e from a 1991 GMC Jimmy with an interchangeable bell housing I know it will bolt to the 5.3 but what about the right hand drive transfer case ( adapter needed ?) the add says it shifts hard and newly rebuilt for $250.00 what do you think? Thanks
awchevy
