Project Mini me
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Cycling her through...
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
A 3 foot jump will let you know for sure.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Heres the driver side which is the last side I have left to do....
Stockish...
Wonder what was eating tire...smh
For giggles... About right sas height...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I think I'd need some king coil/bypass shocks for a 3ft jump at speed...
But at least this side is done...Even though I jave made room for the 33s, I wonder if slogging up a slip and.being semi sacked out if they would rub at an angle... Or eith heavy mud there between tire if it would be clogging...
I am debating.on ultimate size of 33/9.5/15 vs 32 MTs ...
I also think of trimming the rear to match the body line/ equal to under tail light body line...
I want her rock solid before I go off road.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Do you have ramps? If so drive up on 1 and see how it acts. A little flex test so to speak.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
No ramps but thats a good idea...
Im scared if I jump her the front end may explode like Forrest Gumps leg braces when he started running... But maybe I can find like a warehouse area behind strip mall with lowered section for loading trucks and drive up an angled ledge....feelin the sliders...
And in reverse like the pic below... Love their roof rack....
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I have a stone wall out in front of my house we flexed the Jeep on...my truck not gonna try it, I don't feel like laying it on its side.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Well... I just had an unsettling experience.... So my girl walked to the end of the street to the corner store, and I figured I got a few minutes before work, ill go pick her up in the truck.... So I go there wait, pick her up and literralg make the one.turn left to my house and straight shot home....
THE STEERING wheel spins but I slowly realize I am not turning.... I try to get out as I am in the middle of the street, I see sterring rag! Joint where it connects to ps rack spinning freely... While I hope it isnt somehow stripped, I try and kick the tire straight ( and thought I broke a tendon by my right knee- which dissapointed me- as I used to have leg toughness from muay thai but I guess not no more). I was trying like a wu shu inner sweeping kick as I had dress shoes on, but had to run home in khakis and dress shirt, sweating like a pig knowing every second, pd could show up to tow or ticket.... So I grab the jack, sledge, and some 10,14,12 mm and 3/4 ratchet throw that in the prius. I run back jack her up, sledge the wheels right to get by the curb and drive forwards. Jack up again reverse wheels left with sledge then drive back in reverse. Then I sledge wheels right again drive forward and park her... I spend about twenty minutes and get the shaft from the steering wheel. Loosely reattach by rack, then loosely reattach back mear wheel....
Was able to limp her home...
My girl now says "that just scared me from driving that car completely"
I kist think had that happened at freeway speeds I could be.no.longer.
So definatly I will thread lock these 3xbolts now, and make sure they are as toraued as can be, and will nowbe on my smug up every other trip list foor a while until I am sure it is a non issue....
I dont know if they loosened up or what...
So I had to call in which sucks as I started 30 minutes ago...
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Well that sucks but like you said it could of been a hell of a lot worse.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So this is what connects the steering wheel to the steering rack in this car...
This was the bolt that came.loose and the piece popped off....
Had to take off the top two bolts on brass piece to get the assemblyout and re installed....
What sucked was burnning backside of hand on heatshield, and doing it in the middle of the street, but at least its home now...
Two steps forward, three steps back...
Ill get it eventually...
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Gotten quite a ways since I last checked in. Lookin good!
CSFJ
How much flex does your suspension have? It looks (at least from the pics) as though any up travel in the tire will bring it right back into contact with the body. If that does happen, you may have to go back down a size on your tires.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Red locktite
Thats exaclty what I used in all three bolts.
Appreciate it.
For right now it has been.pretty stuff but I havent driven much with everything together. I think 32" is winner... I would live to try a 33/9.5/15...
This is how I limped it home glbefore I started working on her today...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Put the 33 on again... Lotta sledge hammering and angle grind cut off wheeling....
jlyon1006
