Milblazer
- Mar 21, 2013
- Colorado
- MilBlazer
- K5
A thought came to me while looking at the relay mod for the power windows in our square trucks. Could that same mod be applied to a power rear motor? It has an up, down, and off position on the switch just like the side power windows. You could pull 12V right off the junction block and splice the relays in right where the wiring exits into the engine compartment. If you use weather pack connectors the system can be used with or without relays in case you're in the middle of nowhere with a relay that went bad you can just unhook the relays and connect the system back to factory.
