@PrairieDrifter,
Now, today I was over at the shop that's going to straighten my frame and I took the opportunity to open the hood and look at the shifter rod from Lokar that the transmission shop just put in. It looks great, but that's not the problem. The problem is the power hose that comes from the power steering pump and goes on my steering box is leaking at the top of the gear box. I tried to tighten it up here recently before I sent it off for all the big fixes, and I see it's still leaking at that hose fitting.
So what would be the problem with the hose? I've not ever had that problem before and haven't been driving the truck for months. So if I'm not driving it what could cause it to have a leak there? I wiped it off some time ago when I first noticed the leak and it IS coming from the top of the gear box where the hose screws into the port. I can't recall but is there a 'o' ring on that line that may have gone bad? Or what?
Is it a new hose or been messed with? It is possible the o-ring has failed, that would be the easiest thing to replace so why not try it? Did you get the box reworked, or a new one? Check for these small defects, it's not uncommon for an o-ring to get torn, I usually lube up all the o-rings I install with whatever fluid they're for, or o-ring lube.
I had an oreillys fuel pump, right out the box, not o-ring fitting but, it had a small defect on the sealing surface of the pump that the line connects to. Immediately with the first bit of gas through it, it's actually pissing it out, after I removed it and inspected, I saw this defect. It was very small and hard to notice, but caused one hell of a leak.
I'd say if you haven't touched that hose for a long time and it started leaking, the o-ring most likely failed, if the leak gets worse after you've tightened it, it will most likely be the o-ring.
