Power Steering remote reservoir hose???
sticman
Langley BC Canada
Jason
K10 / V10
350 5.7L TPI
I seem to recall there's a factory hose to connect the remote reservoir hose to hydro boost pump when the AC option was installed. I know I can build up something with heater hose, but I'm sure the factory had a cleaner solution. I'm interested to see if ppl have some pictures of the hose routing for the remote reservoir hose to hydro boost pump with AC. And or a part number for the hose i think exists.
:popcorn:
hmmm, :shrug: Never realized there was a difference of AC and Non AC. Guess I"ll have to popcorn this thread too. :popcorn:
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
My line goes from the top of the ps pump over the water pump to the alt bracket where the res is. But it is discontinued, you may have to have it made. Dont use heater hose it will sweat and soften swell up it has to be oil res tubing ...not cheap per foot ...i used two 90' fittings to make the turns...... But mines a big block with coaxial compressor may not be the same
MrMarty51
Eastern Montana
Martin
I got that specialty hose just for power steering fluids/ATF from Carquest, it is some stiff stuff, does`nt loike much of a bend bit it can be slightly curved around obstacles.
sticman
Langley BC Canada
Jason
K10 / V10
350 5.7L TPI
From all the hunting i did, I get to answer my own question. So maybe some useful info for someone else.
There's probably some other configurations out there, but this is what i learned. Even found some big blocks to look at but no small blocks.
On a big block truck with / with out ac the remote reservoir sits atop the alternator bracket, hose running across the top of the water pump to the steering pump.
Ive also seen a big block truck with out ac and the remote reservoir sits atop the two driver side blots of the water pump, hose S-curving to the steering pump.
On a small block there does not seem to be a factory setup with remote reservoir like i thought. Most steering pumps are local reservoir with the fill cap pointing up center or to the driver side.
The diesel also has remote reservoir option but i couldn't find any mounting location info for the remote and the fat compressor.
In the case of the 1985 -1987 bracket that i have. The correct pump would have the fill cap pointing to the passenger side when ac is installed. any other pump cocking dose not fit or allow you to remove the cap or get a hose on with the fat ac compressor in place. The older long body compressor may be a different story as it sits way higher leaving more working area around the steering pump.
attachment.php
attachment.php
Great Info Jason. Nice Addition to the forum. Rep Given. :waytogo:
I wasn't even aware there was a difference as previously explained. For the purpose of your info, I'll add a pic of my 454 with remote reservoir WITH AC.
1986 454 PS Remote Reservoir w/ AC
attachment.php
MrMarty51
Eastern Montana
Martin
The red hose I got from CarQuest will make those bends just fine, and, it seemd to be the same stuff that was on the 427 engined trucks from the seventies/eighties.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Here is a more open view of a 454 front end.
1986 454, with A/C and dual AIR pumps. alternator is removed from top left, AIR pump removed from top middle.
Nice !!! Well have a full round of 454 PS pics before long. :waytogo: Thanks for the addition Terry.
gymbo39
Southern California
Don
C3500
I never saw an answer to the original post other than one from MrMarty51. Is MrMaty51's the only option or is this hose available somewhere?
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Yeah I'd like to know too. My 86 has the same setup as GTME94's. I just discovered my reservoir hose is leaking at the pump and leaving piddle puddles. I can't seem to find a replacement. I took this pic to see if I could get a p/n off my hose but as you can see there's not much left of it.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Good old thread. Our 87' 454. I like the 86 set up bracket when we remove our smog pump. Drill a couple holes and mount that secondary bracket for reservoir. The main bracket is $20 at parts store if I can find 2nd one.
RogerioHR
