Power Steering High Pressure Hose Help
Mark Sprenger
South Plainfield, NJ
Mark
5.7L
Hey guys, trying to get my '82 K20 back on the road but I am having a weird problem with replacing the pressure hose on my power steering. Got a new one from NAPA and it has a totally different fitting. Mine seems to be a simple flare fitting where as the new hose has a nipple on it with an o ring. Attaching a picture of what I have, feel like I doing something wrong. Or maybe someone swapped my steering box? Let me know if anyone has any thoughts.
Mark Sprenger
Mark
5.7L
This is what my return fitting looks like and what my high pressure fitting should look like
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Top pic is a metric o-ring style bottom is a double flare. I just went threw this on my last 2 projects. The one I just double flared the end that went to the pump. The current project I had another pump with the correct metric fitting so I swapped out the fitting in the pump.
Mark Sprenger
Mark
5.7L
So basically my best option is to cut the ends off of the hose and double flare them? Truck didn't have the original hose on it, figuring the fittings that the new hose came with wont work? Why would NAPA sell this if it doesn't fit
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ecause for an 82 it will have the metric O-ring fittings. My truck is an 87 my pump is 67. I just swapped out the fitting in the pump with the original one for the truck now I can use an OE style hose. The return is just hose on slip on fittings.
Mark Sprenger
Mark
5.7L
So that would mean the pump and steering box were swapped out for an earlier model? Both my pump and box have the fittings for double flare.
Georgeb
Wisconsin
George
K10 Burb Z71
Before I modified the new hose I would research and find one from an earlier year that will fit. LMC shows different possibilities. I imagine it is flare/flare, metric/flare and metric/metric assuming in that order compared to years but not totally sure.
Mark Sprenger
Mark
5.7L
Just cross referenced it to rock auto, the earlier ones have the double flare. Guess I'll just return what I have and get the earlier hose. Thanks for the help
highdesertrange
kalifornia
mike
k30
that's what I would do just get the right hose. as a note CCP performance parts sells a neat kit that replaces the hoses with field serviceable hoses. if your hose starts leaking you can go to a hydraulic hose shop buy a piece of hose and replace it yourself. no more cheap junk hoses. their kit for hydra boost also comes with adaptors so you can mix and match any pump, box, and booster. flared or o-ring. the adaptors are available separately. highdesertranger
jbahena95
