jademan
- Jan 19, 2025
- USA
- jade
- k10
Power steering was leaking bad from input shaft location. I installed a new seal kit for input shaft. When trying to bleed the power steering i'm unable to get all the air out. Cant figure out what i'm doing wrong. I turn the wheels from side to side with truck off and front end lifted up and cap off. I'm able to get it to turn relatively free without the truck running after 30 to 50 turns "usually more", but as soon as i start the truck, the wheels crank to the driver side and bottom out. I've retried the process a few times and now it to the point when the wheels bottom out like before, the power steering doesn't squeal or make any indication that its trying to work. I don't know if i messed something up installing the new input seal? Do you think i should rebuild the pump? or should i drain all the fluid and retry the process?
