Power Heated Mirrors with Sequential Turn Signals
81K10
NC
Michael
I was curious about this part and if that is the case this makes finding this stuff even easier. My concern though is that the arm for the chevy vs dodge might be shorter?
The arm on the 94-97 dodge is shorter, since the mirror mounts higher than the GM square. However I am almost 100% positive that the arm diameter is the same. So you should be able to use the stock door mount and arm from the square body while attaching the dodge dumbo to it.
jlyon1006
