Terry Wilkerson
- Dec 2, 2021
- Kansas
- Terry
- GMC 1500
I need to verify with someone what I'm thinking about my power door locks. The passenger side lock works using either door switch. The driver side does not work using either door switch. I did find and print a wiring diagram for the system. I'm trying to eliminate having to pull the relay out because it really hard to get to. I think it working. From the diagram it looks to me like the relay has to be working. The switches just operate the relay only. It's the out put side of the relay that operates the solenoids. Both solenoids are tied together on the outgoing power. So it appears to me the problem must be wiring and or driver side solenoid. Does this make since to anyone?
