Power door lock issue
eskimomann209
Modesto
Marcus
I’m willing to part with it.
I haven’t tested it but it’s a brand new one I believe.
I ordered one when I was putting my truck back together. Found the original when it was enroute. I’m impatient so I mounted the original.
rwljpl
Alabama [AL]
Rich
Thanks Eskimomann
I actually found a relay and got the power locks working again
But apparently they don’t make that particular relay anymore and the substitute I found is getting rare too
Hold on to yours - it’s going to go up in value!
86c10twotone
MD
Roy
I have the same exact issue right now what was the fix ?
rwljpl
Alabama [AL]
Rich
I replaced the relay and the power locks now work. But the relay is hard to find.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Since I’m cheap, I used a power door lock relay from a 90 GM car or truck. It’s not a direct plug in, but other than a black wire (ground) the other wires are the same. I had to cut the old plug of the truck, and splice the new relay plug to the truck. Since the original relay grounded thru the mounting bracket, I need to ground the new relay.
The relay I used looks like this. It’s common on GM cars and trucks
Eighty5ov
Canada
Ov
c15
This thread saved me, I thank you all. I found a cut driver wire for the actuator motor, my power accessory circuit breaker was blown, and that relay is way hidden and the actuators weren’t even plugged in. Plugged them in, got power. And bobs my uncle. Thank you all
rtomrdle
