- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
After many years of trying to decipher what operator's were writing, "what is wrong with their trucks," I think I may have the answer. The OP is trying to add power brakes to a truck that did not originally have power.
@Smelsbad needs the bracket spot-welded to firewall. My suggestion would be go to the yard and grab everything, master cylinder, booster, bracket and push rod from the same vehicle. May even need the pedal arm if it is different.
Take a long chisel and a 3 pound hammer or other tools of destruction to remove the bracket.
You may be onto something here. @Smelsbad is this what you wanted to know? I too could not figure out what the original question was. If so, I'll clean up this train wreck of a thread, lol.
