Power Brake Booster Replacement
davbell22602
Bunker Hill, WV
I Dont
Have
One
I dont have all data since I graduated auto school. Do I have to anything special when replacing the brake booster? Mine is bad
97 k1500 350 3 door
Swims350
Logan WV
none
might be easier to post on a gmt400 forum on it.
I'd say no, just hear it's a big pain to remove the clip from the rod up top on the pdeal. The rest is simple, 4 bolts or nuts on it, and 2 on the mc.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Look at the new part and undo anything thats attached to it and then reattach when yhou have the new one in. Like Swims said its only 6 nuts and a clip on the brake pedal and a hose should take a professional like you about 20 minutes.
davbell22602
Bunker Hill, WV
I Dont
Have
One
That clip is a PITA to get too. Think a hook/pick tool will take it off?
smurph20
Brad
Either hook pic tool or a pair of needle nose pliers
Swims350
Logan WV
none
or your finger, screwdriver, something. I never changed one.
davbell22602
Bunker Hill, WV
I Dont
Have
One
screwdriver dont work. Its in odd spot/position. Either the screwdriver is too short or too long or not shaped right. The dang steering column almost goes in front of it.
Swims350
Logan WV
none
drop the column.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Problem fixed. Now the cruise control quit working.
smurph20
Brad
Make sure you didnt unplug one of the brake switches. There are two of them on those trucks one for the brake lights and one for the cruise. Err maybe its one swtch with two plugs either way sounds like the problem.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Fixed. It was unplugged still under the hood next to the brake booster.
minnesotajoe
