Power Brake Booster Adjusting Rod
custodian
Catawba
William
5.3 LS, 350
I switched from hydro boost to a power brake booster. I misplaced the pin that held the rod to the brake pedal arm.
Was this a certain type of pin or can I use a cotter pin?
By the way, if anyone else does this, I had to drill the adjusting rod hole out to a 9/16".
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
custodian
Catawba
William
5.3 LS, 350
The pin in behind the cover on the second picture is what I'm asking about.
Vbb199
Salisbury NC
Vince
It's like the pin on a trailer hitch pin.. Whatever that's called.
custodian
Catawba
William
5.3 LS, 350
Thanks, I'll look for one at the hardware store when I'm out tomorrow.
texczech
