Post up your engine setups
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Mine:
355 Gen 1 2bolt main block from a 86 Suburban
Ported 193 TBI heads (bad idea, but all I could get ahold of at the time) :(
262/270 .462/.480 218/226 @.050 lift Xtreme Energy Comp Cam
Edelbrock intake manifold
Dynomax long tube headers
And the old Quadrajet! :D
One of these days I hope to pick up some aluminum heads and a stronger bottom end and new pistons to crank up the CR with a 230+ duration cam
Hoping to be able to reach the 500 mark one of these days
82chevy350
Van Buren, AR
Joey
C10, K10, K5
350 std bore
468 gross lift cam
edelbrock performer intake
edelbrock 600 cfm carb
Flowtech Headers
Double roller timing chain
Accel Distributor
Accell Supercoil
Proform Dress Up Kit
CaliDude76
NorCal
Sal
Nineteen Eighty Four
C-Ten (Custom Deluxe)
Three Fifty
Feast your eyes on my monsterous stock 350!!! LOL with a TH350 Tranny.. of course! Had a 305 originally, but had a 350 put it about 20K mi ago.. had to cut the air-cleaner to get more air... it was starving
Swims350
Logan WV
none
The 350 in dad's 84...
010 block, gm 2.02 replacement heads
weiand action plus intake
edelbrock 600cfm vac. sec. man. choke carb
old hei dist.
mallory custom made to fit wires
summit/flowtech long tubes
.010 main and rods crankshaft which is a replacement
gm x rods
cast dished pistons
comp cams 268h cam and lifters
new pushrods
double roller timing set, everything else replaced with new parts as well, but along time ago about 10 years now.
Also has brass freeze plugs done same time as cam and intake went on.
85k10383
Glengary, WV
Ross
K10 Scottsdale
Blueprint 383
Cast iron heads, not sure which casting number, I haven't really looked
2.02/1.60 valves
cam of specs mysterious LOL
Jegs long tube headers VHT silver by me
Edelbrock 750cfm carb
Performance products Weiand air gap knock off intake
Shot at 2010-07-23
Shot at 2010-07-23
CoggedBelt75
Oklahoma
Joe
Engine
Block: 4 Bolt Main
Crank: 3.75 Eagle 4340 Balancer: BDS crank hub Rods: Crower 5.7 Stroker Sportsman
Rod bolts: Crower
Pistons: Arias blower pistons
Rings: Sealed Power
Cam: Isky hyd (BDS grind)
Heads: World Sportsman II
Timing chain: Cloyes double roller
Timing chain cover: Cloyes quick button
Oil pump: Melling Hi-Volume
Pan: Moroso 7 qt
Induction
Weiand 671
BDS Electronic fuel injection
Mine is the 350ci/330hp HO Deluxe crate motor from GM. I believe we ordered it from a dealership in Illinois and was around $4k delivered to my door complete with chrome valve covers, chrome air cleaner assy, and balanced. The only thing I had to do once it was all in and hooked up was minor tweaking on the carb and adjustments to the timing. I couldn't ask for more for the money. Eventually I want to upgrade to a BBC, though, but that'll require upgrades to the rear end, tranny and front suspension to handle the extra weight so that'll be a ways off! :)
Beatdown Z
Newark, DE
Here's my 305, yea! Previous owner said it was rebuilt without machine work. It's got a solid lifter cam that's prob too big for it, some old heads that I never ran the numbers on(2.02/1.60 valves), old spreadbore Edelbrock intake, and topped off with a beat 4160 that I just rebuilt.
greencountry05
Muskogee,OK
Skinny
V1500
BEHOLD THE BOAT ANCHOR!
Is that a 305 or 350?
85k10383
Glengary, WV
Ross
K10 Scottsdale
Aw c'mon, it beats a sharp stick in the eye five days out of seven, right?
MTBR12
