watching a few video's on youtube with a meter would help. You can troubleshoot with the ohm function just as easy as the voltage function on most things. Just gotta know how to understand ur readings.
If you can put your meter leads together and read zero ohms and understand that the connection is made with a zero reading, your halfway there.
1. wire up a 12v light bulb to a battery. Read battery, 12v. Read from positive or negative (your choice....just dont change that reference on the battery) to the other end of the wire going to the bulb. You will read zero. Go to the other side of the bulb, you will read 12v. Now take the bulb out and read the end of each wire at the bulb. You will read zero on your reference, and 12v on the other wire. Guess what, you just verified that you have a (simulated) blown fuse, broken wire, or bad bulb, because u read zero.....then across the open plug you read 12v.
2. Similar thing, wire up a 12v light bulb WITH NO BATTERY POWER CONNECTED. Read from the positive or negative (your choice....just don't change your reference) wire and read the wire going to the bulb. You will read zero. Go to the other side and you'll get a small increase in OHMS (2-20). Now take the bulb out and read the end of each wire connecting to the bulb. You will read zero ohms on one leg, and OL (infinity or very high) on the other leg. Again, you just verified that you have a (simulated) blown fuse or broken wire or bad bulb, because u read zero....then across the open plug you read OL (or infinity/high) OHMS.
NEVER EVER PUT THE METER IN THE OHM FUNCTION WITH BATTERY POWER CONNECTED!!! You'll blow the fuse inside the meter and you won't be able to use the ohm function until you open the meter and change the fuse.
Another tip, if you're troubleshooting something that is of great distance.......such as the fuel sender wire to the gauge. Get a long length of speaker wire to extend your meter leads.
Like I said before the #'s, to test your meter, put it on ohms and put the leads together and you should read zero OHMS. If you don't your meter has a blown fuse or bad meter leads. Then go to town with the above #'d steps.
Hope this helps
