Camatruder
- May 11, 2016
- Belgium
- Rik
- K5 Blazer
- 350ci / 5.7l
If i grab the steering shaft in the engine bay close to the firewall (thus above the rag joint) in one hand and the steering wheel in the other, I can feel a fair amount of rotational play. I can not understand how that is possible. There is no play between the steering wheel and the splined shaft because it is pressed on and the rest is imo only a shaft that sits in a housing hold in place by bearings. I can see how these bearings can go bad in such a bay that the column can be wiggled up and down and maybe in and out but I can not see how these bearings can cause directional play.
Any input is highly appreciated.
