Play in steering box at normal operating temp.
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
When starting after the truck has been sitting for a couple of hours the steering is great. As things warm up there's an increasing amount of play in the steering box when driving straight forward, not in cornering. Everything is stock, power steering filled with full synthetic atf which looks and smells good. All other steering parts have 0 play. I changed the box with a rebuilt one from rockauto but that didn't help.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Possibly the synthetic fluid. Thinning as it warms up?
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
Well i finally found the time to flush and fill the PS with GM approved PS fluid but that made no difference.
1979k10
Nevada
Dave
Rag joint?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
I cant say ive ever run across a temperature related steering problem. I would check and see if the fluid is foaming up when its hot and causing problems. possible trapped air in the system? To purge air turn wheel till it hits the stops apply enough pressure to force the bypass valve open (make it whine ) 2-3 seconds turn wheel to opposite side and repeat, do this cold if it is foamy it doesn't work as well , do this a couple times and try it out. keep your fluid level from getting to low while doing this . possible bad pump? possible kinked or collapsed lines?
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
I tried and checked everything in the previous post but no change. I own this truck for 5 years now and it really has had this problem ever since. In the past years i changed about every steering component including the steering box and pump that were rebuild ones from rockauto. Which leaves me with a couple of questions: how much play is normal? Is this a design fault, from the center position the idler arm seem to go upward just a little before moving sideways. There is no crack in the frame. There is zero play in other components.
Should the adjusting of the steering box be done with cold or hot ps fluid, with engine running or not?
Shorty81
Baby Boomer
North West ohio
Darren
Don't rule out steering box. Some rebuilt box's are no better than what you took off. Take the weight off your tires, adjust your lash adjustment in until it hits home, then back off 1/4 turn. Also check your spring bushings.
Camar068
10 yrs Air Force
@Shorty81 curious what do you mean by home? Thanks
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
there is a high spot on the worm gear so when the steering shaft is at the center of travel it will be stiffer. when its to tight as you turn the steering shaft you can feel it.. that's home.
Shorty81
Baby Boomer
North West ohio
Darren
Thanks C10, turn in lash adjustment (clockwise) until it just starts to tighten. Do not over tighten. Then back off 1/4 turn. If you feel dragging or resistance in steering back off 1/4 more. Hope this helps.
highdesertrange
kalifornia
mike
k30
a couple of points,
I only use ATF in a emergency. it works but always causes problems.
never ever never try to adjust a box unless you absolutely know what you are doing.
never buy a rebuilt box from a parts store. go to a well respected medium/heavy truck repair place and ask them who rebuilds their boxes and take your box there. commercial LEO's don't mess around with loose boxes they will stop a truck immediately and not allow it to proceed if the steering is loose. therefore the rebuilders are held to a much higher standard, if they don't do top notch work they are soon out of business.
highdesertranger
ExtraZ
