brendo613
- Apr 30, 2012
- Southeast PA
- Brendan
- Vandura 2500
- 350ci
Hey all,
I'm hoping to get some info from GM gurus, at whatever price I have to pay (I'm prepared to be very laughed at). I have an '88 5.7 TBI Vandura 2500 with a 700R4 acting up, and I don't want to play games - well, not with fixing an automatic at least Don't want to spend more than $300 on a trans, so I gotta plan out a swap to an SM465.
I found GM code GU6 in the glovebox: assuming I have a 3.42 rear with a 700R4 (and 220/75/15 tires), the van cruises @ 65mph @ 1848rpm. I played with this handy gear ratio calculator until I got a setup that looks usable. With a SM465 and a 2.41 rear (and 220/75/15 tires), 65mph comes at 1861 rpm. The rest of the gear range looks usable for getting up to highway speed as well, heh. Unsynchronized 1st will be fun, too (planning on using L as 1st).
So - I need help with the flywheel and clutch release mechanism part. I don't mind cutting and welding to get a pedal assembly into place, but I do mind spending a lot of money - so Novak's hydraulic release kit is out of the question. Does anyone know if a C / K series pickup clutch pedal assembly will fit in the van? Also, I've heard that in 86 the rear main seal design changed - so I'll need a flywheel from an '86 or newer, correct? Driveshaft lengths are going to get creative, too. (Just trying to sort major hurdles beforehand.)
D'oh. This isn't an easy one ... but man would it be cool
