pinion yoke
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
ive watched many videos, ive found out i have alot of the tools. one particular video a man uses a straight edge and a digital vernier scale and finds center line of the axels, pinion gear from the face of the axel housing. assuming your old set up was good you just put every thing back to those same measurement. But I over torqued my crush ring so when i take mine apart im not shore if that method would work because I don’t know if my Pinon depth is currently right. I guess I can grease the gears and Check the pattern before I blew it apart.
Pattern gears and check backlash before you disassemble, if everything is in spec (or close to it) just put all the shims back where you found them and recheck after assembly.
Unless you are replacing the ring and pinion try to just keep everything the same.
Josh577
waverly ohio
josh
k20
im keeping the same gears. thank you for the advise that is what ill do
The shims are to compensate for housing differences,90 percent of the time even going back with a new ring and pinion you'll still use the same pinion shims,and in your case,nothing should change just doing bearings. @Josh577 when I worked at the dealer we were taught with all proprietary gm training, but you won't have any problems. Do yourself a favor go online and buy yourself a crushsleeve eliminator it will make your life easier. If you have trouble getting the carrier shims back in,post that your having troubles we'll get you through it.
Josh577
waverly ohio
josh
k20
thank you
F1r3truck
