Pcv or not to pcv?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
In your house it wouldn't matter what was on it, there'd be too many children in the way to catch it on the way down before it hit the floor. ;)
And probably eat the buttered toast
82sbshortbed
Fuckemall!!
SE Texas
Doug
Why don't we just plug the pcv value hose up the cat's ass and see how much crankcase pressure it takes to pop him.
Rusty Nail
Rusty
350sbc
Well, if you put butter on the floor it would be slippery and might cause an accident.. OSHA may show up and ruin all the fun. :( Heads up!
AND! Shizzles nizzles -I never get to clock out.
Michael Benardo
Vallejo, California
Michael
C 25
292 Cubes
I suppose it is possible that the oil pump pressure relief valve could somehow get clogged and cause oil pressure to increase but NO, mine is fine. Oil pressure has never risen over 60-65ish and thats when cold or warmed and in throttle. Otherwise idling warm its 35-40ish
What about at road speeds? It shouldn't be much over about 45PSI.
Michael Benardo
Vallejo, California
Michael
C 25
292 Cubes
So....My passenger rocker cover is sealed up tight. As in it has a push in oil cap and no venting to the air breather. Perhaps this is contributing to something as it has no way of pulling in air from the passenger cover like OE. Im gonna pull the cap and replace it with a breather/filter and see if that helps.
Hope you can solve the problem.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
Aww **** it. Ive discovered bigger problems. NOw the oil AND WATER seem to be coming FROM the intake. Fuckity **** @Ricko1966 is right. Ive gotta tear this bitch down and see whats going on.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Well, after many replies I went with the pcv valve on driver's side valve cover.
Had to switch rubber grommets to get it to fit but, that ain't ****.
Now k&n filter on pass side and pcv valve on driver's side valve cover.
Now I'm gonna get some gas and take a ride. Maybe do a burnout. :burnout: lol
Poppy 87
Bloomingdale GA
R10 Silverado
IMHO I think it depends on how thick the bread is and how old the cat is. It doesn't make sense that a young cat would have knowledge and skill to turn over if it had too big of slice of bread tied to it.If I know someone's going to argue it doesn't matter how thick the toast is.
Pretty sure the cat lands on it's feet regardless of age or where the bread is tied
See I knew this would Start an argument.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Really struggling with that motor brother, damn what luck
Vbb199
Salisbury NC
Vince
See I knew this would starr an argument.
Ask me how i know, they all dont land on their feet
HowPoison
