Passenger window troubleshooting, help please
tj43
Little Rock
TJ
V1500
The 88 Suburban is being moody. Last week it was the heater core, this week it’s the passenger front window. That window has always had an intermittent issue. Specifically, it has always worked from the passenger side switch (even when the driver’s side is being moody), but it only works intermittently from the driver’s side.
Yesterday, after finishing the heater core swap, it went down perfectly fine from the driver’s side switch. But now, it wants to stay there. No movement from any input at either switch. All other windows function properly.
First question: could I have done something during the heater core swap to cause this?
Second question: how do I even start diagnosing this? I am a complete neophyte when it comes to the electronics in older cars—so speak to me like I am really dumb (because, in this instance, I am).
I have this tool (photo below). I have no clue how to use it. Thanks in advance and I apologize for being so daft on this one.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Check your "conversations", I sent you a message..
tj43
Little Rock
TJ
V1500
Nick. Thanks for the message. I just responded.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Likely it's the master switch or switch connections. I have problems with mine. Sometimes I have to wiggle the switch
Scott91370
Burleson, Tx
Scott
Sierra1500
I had this issue on mine (only 2 door truck) and the connector/plug on the switch had a broken wire. Sometimes it was close enough to work other times nothing. Super easy fix but my diagnosis was just pulling on the wires.
2manysquares2care
