Pass window in a bind
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Ok i don't know if this window is in a bind because the motor froze or something else is got it stuck. I've put my hands on both sides of glass and it won't move. Looks like a bitch to get too the motor too. Lol
RoryH19
Rory
R10 Silverado SWB
hmm...it's possible the gear jumped and you are stuck. have you tried to loosen the 4 screws that hold the motor/regulator to the door? it may give you enough room to maneuver. Also the motor is attached to the regulator by 3 screws if I recall. no more than 4 which you can also try to remove. you can also loosen the rear window track screw for more front to back room.
Big Chip
Michigan
Kevin
C35
Does it sound like the old motor is trying to do something when you hit the switch? Bang on it with a hammer, that worked for the Fonz.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Haha the po said it used to work then just stopped. I have to help the driver side with my hand. Have a new motor for it too. Lol
Big Chip
Michigan
Kevin
C35
My 86 GMC had the same issues. The windows would get slower and slower until they just wouldn't work. I found cleaning the all the tracks, rollers, etc. would fix it for a while without actually having to replace the motor.
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
Had same problem with my Burb. Fixed it by replacing them all with manual regulators. I also deleted power lock actuators. Got tired of them working slow or not at all! Replace your window channel weather strips and lubing all the slides will help
ejulio
