Part Number for Front Tank Bracket - Passenger Side
Mike Gresham
Hello; I am adding the passenger side fuel tank to my '84 K30. I picked up a pair of used drivers side brackets and thought they would simply bolt on, but no. The frame slopes downward at the back of the cab towards the front, and that is why the front tank brackets are shorter than the rear brackets. Problem is, the drivers side front bracket will not simply bolt up on the passenger side due to the nuts which are welded onto the bracket at the factory are in the wrong position. The nuts on the drivers side bracket are positioned at the 8:00 and 2:00 position, however on the passenger side they must be positioned at the 10:00 and 4:00 position. It seems GM produced one bracket to be used either on the left or right side, but with the nuts welded in different locations. Anyway, I am looking for an original passenger side front bracket which I can clean up and install the new strap to. I looked at all the Chinese junk, and just cannot bring myself to use that stuff on my truck. If I had the GM part number of the OEM front bracket for the passenger side, I would put in a strong search. Any help with finding an original bracket or at least the art number will be appreciated. The photo is of the drivers side front bracket showing the nuts at 8:00 and 2:00.
AKguy
Alaska
Randy
K30 Crew Cab Silverado
The number for the 1981 bracket appears to be 467526. Not sure if 84 is same. Ref for 1979-81:
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
I would weld or find a friend who could weld nuts in the collect location :33:.
zapattack
