Paint Help: pearl question
chubble
Eastern, NC
Custom Deluxe K10
I have it in my head that I am going to paint my truck in the next month or so (as soon as the forecast looks good). I am going to attempt the $50 rustoleum paint job. With this said, I don't want to kick off a debate about whether or not I should do rusto or single stage, I really want to try this method.
My question is:
I am planning on buying pearl flakes for the paint to give the color some depth (https://www.paintwithpearl.com/candy/pwpPewterGrey/pwpPewterGray.htm). I want to know if the pearl will tint the paint that I choose? I am going to attempt the go for a dark pearly grey color. If I add dark grey pearl will it tint a lighter paint (white or smoke grey) closer to the color I am looking for or not. (what does colored pearl do to normal paint?)
robert8096
Goose Creek SC
Robert
The stuff in the link you provided is to be put in the clear of a base/clear paint job. I doubt it will work with a Rust-Oleum paint job. I assume you are going to use the quart or gallon Rust-Oleum paint. If you are spraying that then it will need to be thinned to spray correctly.
Here is a good site about painting with Rust-Oleum paint either brush on or spray.
Good luck and give us updates.
http://rolledon.forummotion.com/
robert8096
Goose Creek SC
Robert
There are some impressive rolled on pant jobs in that link above. You know we are pic ****** so post up your progress.
southbaymiller
