Boone83K10
- Feb 4, 2013
- Boone, NC
- Benjamin
- K10
Yes
Well, i dont think it has a 700r4, in hotrod's thread for identifying one, i dont have the numbers on the back passenger side of the transmission that should be there, no numbers there at all.
No clue what kind of transmission entirely.
Other than the number thing, it looks quite similar to the 700r4 (atleast on the passenger side)
For tires its got 33's, and the guy said a previous owner had put a lower axle ratio into it, he didn't know what ratio though.
And, the indicator goes:
P R N D 3 2 1
D i dont believe has a box around it, don't remember one and i'm almost certain it doesn't.
Above it, it says automatic overdrive, but it is not an automatic overdrive.
Any clues as to how i will know what transmission i do have and all?
Lockup feels like another gear. It allows the engine to ruin at lower rpm at cruising speed. Easiest way to test its to get up around 60. Lightly puts the brake pedal, does it feel like a downshift (do engine rpms go up)? Let off and see if it "locks up". If you dont feel a change then the trans isn't locking and can run hotter and burn up.
Sorry for this to be so long since then, but why would it not have lockup? I dont see the point in needing to test to see if it does have that since all mustve come with that, so that no one would be burning up their transmissions
If it was originally a 3 speed and someone installed a 700r, you might not have the wiring for the lockup hence the simple test. The test really does work well
Sent from my Nexus 7 using Tapatalk
