Ordering new Seats
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
You know I really like them. I was skeptical after the issues I had with installation, but at the end of the day it actually worked out. I will say a couple of things though:
1. As with all aftermarket seats, they sit pretty high. The universal subframe design used by the manufacturer results in a pretty high seat. Not so high that I feel like I'm in the roof, but I definitely feel like I'm perched up there. I do have a much better view out the windows though.
2. The seats feel like they may be designed for a bigger guy than me. The seat bottom is fairly wide and could handle a much bigger ass than mine. Also, it seems like the cushion is designed for a slightly longer leg. I'm only 5' 11" so I'd say a 6' guy with a few more pounds than me would probably fit better.
3. Silly, but the built-in cupholders need to be deeper. I would not trust them with a drink going around a corner at all.
4. I definitely lost a lot of legroom in the back. I'm not sure how or why, but there is definitely a lot less space compared to the bench seat. If you look in the pics, I used to be able to fit that sub behind the passenger side of the bench on the floor. No way could I do that now without pushing the passenger seat way forward.
So long story short, would I do this again? I think so. I did have issues, but the company ultimately took care of me. Are these seats perfect? No. But I think I can make some the issues above a little better once the warranty is up and I'm free to modify things a bit.
Now all I need is a friggen headliner!
Vpilot
Colorado
Thanks for posting this. I just ordered the same seat for my '84 in gray leather.
da_raabi
FloriDUH
Adam
c30
Good luck and post up when you get them installed. Are you installing in a single or crew cab?
Auburn, Washington
Those seats look awesome! And probably feel even better!
They don’t look like they’d fit in a reg cab pickup. Because I’d consider it if they did.
But they look to have a much longer seat cushion and the seat back is pretty thick.
the buckets with jump seat and console is a perfect combo.
da_raabi
FloriDUH
Adam
c30
I've actually seen pictures of these seats in single cab trucks before. That's how I found out about them in fact. So they might just work!
I will say the build quality is not exactly OEM. The center seat is a bit weak, but a little elbow grease and some heavy duty hinges would easily fix that. Otherwise the seat fabrics and foams seem very durable.
Oh, and plan on modding the cup holders. As built they are basically glorified coin trays. My plan is to pull some out of a junk yard car and fab them in somehow. They just need to be deeper is all.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
I ordered Procar Scat seat hope they fit like yours! :)
1990Suburban
