Operation "Save the driveway"
Old60Driver
1983 K20 Silverado
Houston
Michael
K20 Silverado
Did a small top end job on my 83K20 (cam, heads, intake), and she's running great! However, I've got some leakage on the TH400. Going to try to pinpoint it tonight. Leaks noticeably more if I let her sit for a bit. Going to wipe everything down, start her up and watch. I don't have any of that leak detector yet. It's on the list. lol I've anticipated shift seal, dipstick, modulator and maybe the speedo. I'm going to double check the pan bolts too. She only has about 67K miles on her, but I know the rubber can harden and all that. Tempted to just change these parts out, but as I'd had to change out a part, when an o-ring would work.
What say y'all? Any other places I should look?
Thanks!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Go to your nearest parts store and buy a bottle of A/C oil with the fluorescent dye. You will also need a black light, you can get that at the parts store also. Add a little to the fluid and take it for a drive.
Once the drive is over and the truck has cooled down, crawl underneath and shine the light around. The black light will highlight where the leak is coming from.
If the dipstick tube Oring is leaking, inspect the groove where the o ring is positioned. They are notorious for rusting or cracking. If that’s the case, trash all of ot and get a dipstick that takes the boot type seal. It’s a much better design.
fr3ak5how
