Olds 350 diesel to sbc swap
Ryanbrown36
Ontario, Canada
Ryan
c1500
Just hook everything up as normal,leave your selector valve set to drivers side tank. When to run the passenger side tank syphon the diesel ad a couple of gallons of gas drive it a couple of days syphon it again. Fill it,done.
Thanks, really appreciate the help
Ryanbrown36
Ontario, Canada
Ryan
c1500
Welcome to the club fella. I just passed up a Canadian GMC that was a 5.7 diesel. Good luck in your swap & daily driver.
HS
Thanks! Where abouts are you located, don’t see many 5.7 diesels left. Mine was actually made that the Oshawa Ontario plant a few minutes from where I live. I’ve yet to see another one so far (just curious where you saw it)
Strick
Dunn, NC
Harold
C20 Crew
I'm in central NC. This truck I looked at was a loaded Sierra Grande. All power, tilt, cruise. It had a Starburst in the door with Canada inset. I passed on it due to price & condition.
HS
Ryanbrown36
Ontario, Canada
Ryan
c1500
HS
That’s hilarious mine is a loaded sierra grande with all the same options, I only bought mine due to how unique it was and the body was immaculate knowing the how bad the motors could be but was still worth the price I got it for
fofiddyfo
wisco
R3500
Nice truck, man! Welcome from Wisco!
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Nice truck. Remove diesel, fill up with gas. Done.
JBswth
Vallejo, California
James
C25
292 cubic inches
Hi guys, I’m looking for some help on my olds 350 diesel to sbc swap, I have completed the swap and will be starting the truck up soon but have some questions about the tank situation. I have a dual tank setup and replaced the driver side tank with a new one to make sure there was no diesel left but my old passenger side tank is still on the truck and would like to know if I should plug that off somehow and where it’s best to do so(my fuel lines are All fresh from the new tank to the motor) for reference I’m 17 and have been doing this by myself so might be a dumb question but don't really know what I’m doing and want any old diesel getting in my fuel system. Thanks in advance
If it is only a few gallons, it won't hurt. Just fill it up with gasoline. After you run one tank of gas through it, it will be free of all diesel.
J. B.
JBswth
Vallejo, California
James
C25
292 cubic inches
Too bad you have already done the work. I would have suggested that you replace the heads and intake with Olds 350 gasoline heads and intake. That 350 diesel, as bad as it was, is indestructible when converted to gasoline.
J. B.
Ryanbrown36
Ontario, Canada
Ryan
c1500
J. B.
I did look into this before my swap although this motor swap already has me in over my head as I don’t have anyone to really help so it’s all what I can find on the internet. Would’ve been sweet to do it though.
wj35
