SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
Ok this is going to sound a little odd to anyone that isn't a flashlight guy, but flashlight guys will probably find this interesting. So I've been looking for a flashlight to mount in the square. I wanted a old school Magcharger, which is the rechargable version of the maglite. I could have gone out and bought a new LED magcharger, but I really didn't want that. What I wanted was something at least pre-1992, as after that the tube for those lights were made out of a thinner gauge pipe, but my preference was as close to the same year as the truck (84) as I could get. So just before Christmas i found a magcharger on E-bay, the seller listed the serial number and it came back as a 1986. I took it home for a mere $50, seller listed it as well worn, but functional. So I sourced a new reflector, glass, spare bulb, o-rings and battery, didn't buy any of it ahead of time, but wanted to know where I could get what I needed. I took delivery of it today, it does physically look well worn, but whoever owned this flashlight before me must have depended on it functioning. Good bulb, good reflector, not a scratch on the glass. Under the tail cap is a good spare bulb, the battery pack is a 3,500 NiMH battery (factory would have been 2,500 NiCad), battery pack looks like it very new, but yet to test to see how long it'll last. All of the O-Rings are in good shape and have a light layer of lubrication on them, I'd guess silicone or maybe it's just Vaseline, but wow, that's the kind of stuff I'd do not something I'd expect to find on a 34 year old flashlight! The only thing I can find that isn't just cosmetic is that the rubber on the switch is starting to deteriorate.
I'll use it over the weekend and see how the battery life is. Then I'll order O-ring for it, one more spare bulb and a switch cover and it should be good to go.
So the plan for installation is to hardwire the charger, and mount the charger in the truck, but I have questions.
#1. Where to mount, I was thinking of mounting it vertically behind the drivers seat belt so it could be reached easily from outside the vehicle and would be out of the way while driving, and still somewhat reachable from inside. Another spot would be on the floor under the front part of the seat, my biggest concerns about that would be kicking it and damaging the charger, or moisture or mud or flashlight coming loose and getting under the pedals. Not practical to mount it on the hump as I have a center counsel mounted there. I could go overhead I have a home made thing similar to a shelf it, that I just built, but of course if it broke loose it could hit someone in the head. So I'm open to ideas, but thinking behind the drivers shoulder belt part way up the cab would be best.
#2. How to wire it? Two basic options key on only or constant power, the instructions with the magcharger recommend wiring to key on only power and I'm thinking of doing just that, but also wondering if that is what is best for the battery, I'm sure someone knows more about NiMh batteries than I.
Thanks, oh and here are a couple pictures.
@Rusty Nail I know you have said your into flashlights, and there are pictures in this post so I thought I'd tag ya. Plus more pictures will come when I mount it.
