74 Shortbed
- Aug 12, 2013
Check the bypass in the filter adapter.
yesterday I started my 454 and it lost all oil presser after start...
Be the wise thing to do if it's starting to get tired..I talked to the shop yesterday Dave sead he thinks it is plugged off by dirt dobbers has got in the eng when the intake was off . So I got to stinking if I am going to pull it to just have the oil passages cleaned and a inspection done and spend $500 I should go ahead and have it freshened up and the heads done put a new cam in .Would like to put a good loopy cam in it , Spend my dollars wisely and have a fresh engine when it is done that will run for a long time with no issues.![]()
Just know that a lopey cam can cause several new problems, such as low vacuum for power brake booster and poor throttle response. If your trans is an automatic with a "tight" stock torque converter, it will get even tighter, so there's a good chance you will need one with a higher stall speed. You will also need a different vacuum advance canister and transmission modulator, if so equipped.Would like to put a good loopy cam in it.
