- Apr 11, 2017
- kansas
- Rick
- c20
I don't bring them to the maximum mark,anywhere between the maximum mark and the minimum! mark is considered good. Running them in the middle to low side helps keep windage down,I run on the low side, its a little racer trick to free up a couple of horse power. If your engine uses oil you will need to check it more often.
