JT58
- Aug 1, 2023
- Naples, FL
- JT
- V10
I need some help diagnosing an oil leak in my 1987 Squarebody V10 with a 74 5.7 in it, SM 465 manual 4 speed. I have an oil leak, drips that originate around the starter dripping from both sides and flows down the protective plate at the bell housing and drips on the floor. I have looked all the way up the back of the block to the top of the engine to trace the leak, around the valve covers, all dry. Top of the engine is dry. It has a new rear main seal and oil pan installed by a shop 6 months ago. I just installed nice new valve covers and gaskets and that for sure is not the culprit, no change in the oil leak. Dry around the dip stick tube. Is there anything above the starter I cannot see that oil would be leaking from?
I have read other posts and some conclude it is the rear main. I would hope not as if it is, it will need to be done again. The shop that did it took 2 months, leaving the truck baking in the hot FL sun. I won't go back there again. I have found a better shop I will bring it to. But it for sure will suck paying another $2500 for something already done. (I could have a nice new engine for 5K). Hard to find good shops these days. I like doing my own work and usually do and usually results in a good job but pulling transfer, trans out is too big a job for me.
