Nv4500 questions
Erik1
golden
Erik
Gmc V2500 (V 20)
Do NOT put synchromesh in your NV4500! trust me. I have done this conversion on my truck that had an SM465(muncie), I researched and researched and lots of people told me to just use gear oil or synchromesh which has what's called a "GL-5" rating and designation. The correct oil to put in an NV4500 is the GL 4 designation which has different additives that work correctly with the type of friction disc packs in that transmission. GM and Mopar have part number designation's for it. GM is "10-4055". Mopar is "4874459"
A friend of mine did an NV4500 conversion and used gear oil and it started slipping and we determined he really needed the GL 4 oil, which unfortunately isn't super cheap but it's not the same oil as "syncromesh".
I've double checked on Mitchell on demand, make sure you put GL-4 oil in. Hope this helps.
hungry joe
marcellus mi
dennis
c30
can I just replace my sm465 with a nv4500? would like the overdrive, I also have a 400 th,with gearvenders od,might use that cause the older I get,i don't want to shift anymore!
SquareRoot
Yep. I have done it. Is this a 4wd?
hungry joe
marcellus mi
dennis
c30
sorry, been busy,thanks for the reply! its a 2wd 1 ton,1979 non daully.
mgarland
West of Indy
Mark
K30X2
Big
Erik is exactly correct, the only fluid you should run in the nv 4500 is gl-4 rated gear lube. Gl-5 will attack the synchros in it and I've seen them delaminate and make it almost impossible to get in gear. The person that said something about using a amsoil is also correct. That is all I used in all of my dodges and never had any issues and I was about half price.
Mark
GorillaHumper
