SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
So, I have wrapped up the complete teardown and overhaul of my NV4500. I'll get to that in a bit. I figured I should take a deep dive into my 205 t-case before going through all the trouble of swapping everything out. Glad I did. Ended up putting a complete rebuild kit in it as well. I also modified it with the ORD twin stick rails and shifter. I have had the shifter for a few years now sitting on the shelf. However, it was a floor mount unit I was going to use when I had the turbo 400 in it. I realized the floor mount won't work with the 4500. Unfortunately, ORD is back ordered in shifters for like a year. So, I modified mine and made a mount so it's attached directly to the trans.. I also had to modify the shifter handles to get them next to the trans shifter so everything fit on the trans tunnel. Since the top of the trans tunnel was now swiss cheese I just decided to fabricate a removable access panel. It took a while hand forming it but it fits and seals like a glove. The metal I had was twice as thick as the floor sheet metal, which made it tough to form but it's solid. I powder coated the panel, shifter and bracket. So far so good. I should have the t-case put together tommorow and the unit (trans/shifter/t-case) bolted together.
