Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
Thanks!I'll get the measurement in the morning.
True. I figured the rise of the crossmember from the bottom flange of the frame wouldn’t change though. I could be wrong, but I thought a W crossmember would be the same on a k20 and k30.
Really? I have the flat CM and it’s always been mounted under the frame...Your crossmember should mount on top of the bottom frame lip... inside the 'C' of the frame. A K20 will have it mounted to the underside of the frame.
I thought I’ve seen other cucv trucks the same way. I need to see if I can find some pictures.
It's impossible for my x member to mount inside the rails. There's only 1 set of holes in the frame that corresponds with mounting it underneath the rail.
Right, but if it were a taller K30 frame, the holes would be there.
I was one of the things I considered. I checked clearance, but maybe I missed something. I’d be curious to see a truck with the 4500 in it from the factory to see how much perimeter clearance they have. How much space did you end up with around the edge?I have a NV4500 conversion in my 1985 K20. My trans is a 1993 GM unit. My tower would torque over and clunk my floor cut out. I had to make the hole larger. I know you’ve probably already thought of this and checked clearance. Have you checked your motor mounts? That could cause lots more movement than you would anticipate.
All valid points.I glanced through the comments briefly after watching the video.. Didn't see if it was mentioned but that trans/shifter tower seems to move around an awful lot in that hole between accelerate and decelerate in my opinion. I'd be rechecking the mounts and verifying they are tight/to spec. And i'd also take a good look at your motor mounts as well. Especially since you just put brandy new trans mounts in, you really need to install all new mounts together. New engine mounts= new trans mounts and new trans mounts= new engine mounts. The torque has to go somewhere and it will find the weakest link. Dad taught me 30 years ago "If you feel it in your hands it's somewhere in the front end, you feel it in the seat of your pants its in the driveline or rear end" and I've used that ever since. I've seen rearends with excess play make it sound like its up in the trans. and it could be in the motor mounts emanating back through the trans. I saw locker mentioned but figured i'd throw my .02 in the ring.
