NP205 Front Yoke U-bolt Strap Kit
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
Direly need the u-bolt strap kit for front yoke on np205. Would also take the straps/bolts for front of front driveshaft onto 10 bolt diff. Thanks guys
AND a yoke for my rear 10 bolt differential.
All very important, i got what i could locally, i need you guys!
205 front yoke should be bolts... right? It's a cardan joint attached to a flat plate that gets bolted to the 205 I thought
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
no threads on the yoke itself, i think it's meant for a u bolt. Still learning this
sirweesarunch
Oceanside
This is the front driveshaft , the joint and the front unit thats bolted to the np 205.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Some 70's models I believe were the ones with the straps instead of a flange mount. This is a divorced dodge np205 but same difference, so he's correct in what he's asking for, if that is indeed what he sees.
What you couldn't find I would just go aftermarket, like the yoke and possibly the straps.
Pics of what you are working with would help. The front axle straps and bolts should be available at almost any parts store, same for the rear yoke. Although all of that would be cheap and easy to get from any pick-n-pull.
I've never seen a squarebody 205 that didn't use a front cardan joint. Maybe there are certain models and years that had a standard yoke, but I've just never seen one. Hopefully the OP will post pics or an update of what he figured out.
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
yeah i'm going to take some photos. like i said, i'm quite new to driveshafts/yokes, etc. i do know that long ago someone made the Jimmy into manual from automatic, but that shouldn't interfere with the front portion of transfer case, unless of course he swapped that too, i'm not sure
ALSO i had ordered a Dorman yoke for my rear diff online, and went to a local parts store for the straps for the front (i took the front driveshaft in) I definitely have the kit for the front shaft to front diff and he gave me bolts he "may think" will work and i went to go put them in and there's no thread; it needs a u bolt i think. If anyone has a late 80s Blazer/Jimmy with a 205 i wouldn't mind some pictures as to what you have going on
There's no telling what got put in with a swap. Pics will be key. It is almost assured that the transfer case was swapped out when it went from automatic to manual. There's a lot of combos that COULD have been in there to start and a lot of things that COULD have been swapped in. Is the front and rear diff stock?
The stock square body corporate 10 bolt fronts are U-bolts and have nuts on the back like this: https://www.drivetrainamerica.com/s..._Mu_LPja86cJ0gVbCwaoAcx4PP3KbE-oaAttzEALw_wcB
Some might have yolks that accept the regular straps and bolts as well, but it sounds like the one you got does not.
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
Both yokes on both differentials (GM 10-bolts) take straps; are both threaded. as i've said, later on tonight i'll take pictures and get them on here, i'll cover all yokes/meeting points. thanks again
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
I have one now actually, this is the rear of the 205, i believe the front will require the same, as it is not threaded
Yeah, if you have a yoke like that on the front driveshaft it will take the spicer u-bolt kit I linked in my previous post. The flat plate would have been stock, but your unit has obviously had some aftermarket modifications done when it was swapped to manual. It wouldn't have had that SYE kit on the rear either. Stock would have been a slip joint yoke.
yevgenievich
Place
Name
Year
Model
Size
Weren't most np205 rears fixed yoke?
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
So i was able to get pictures sooner than expected:
Pictured first is the rear diff yoke, its stripped out and i have another one on the way, as mentioned above. Pictured after is the front drive shaft i was given: the last owner told me i needed a longer one, it wouldn't fit with the "new" lift. Gave me the old one anyway and hey, IT FITS. So he ran it without the front for a while so i have to clean the mud out of the front diff yoke threads and have the strap kit for that. So anyway, assuming the bulkier end goes to the transfer case, it looks like it may take u-bolts? i mean i guess it'll have to. Then after the transfer case photos are the front yoke. Help me figure out this mess! Last owner left me with a drive train mess!
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
If i can use my current driveshafts that would be best, especially being i spent $600 getting the rear one duplicated. The front, if i need to get a new one if you guys suggest new yokes/flanges, i understand. I want this done and i want it done right/to last. Open to all ideas
MR87R10
