oneluckypops
- Feb 6, 2011
- Sedalia, Mo.
- Luke
- K30 SRW
- 5.7 Fuel injected Vortec/ 4L80E
The NP203 Has 5 locations for the shifter, Starting in the position closest to the seat it should be:
4 High Lock
4 High
Neutral
4 Low
4 Low Lock.
The tail housing is aluminuim but the rest of the case is Cast.
The NP205 has 4 shifter locations. Starting from the position closest to the seat it should be:
4 High
2 High
Neutral
4 Low
The 205 is easilly recognizable by its Heavy cast iron case, There is also a small circular plate the bolts to the rear of the case Aprox. 2-2.5" in diameter, It will have 3 Bolts that hold it to the case. The shifter handle on the 205 is just round.
The shifters are Different aswell, The 205 has a center pivot bolt in which the shifter pivots on.
The 203 has 3-4 linkage rods, and the shifter itself is actually a side rail shifter style. usually the handle is like flit iron that tapers back down to a round shaft for the nob It is also usually chrome plated.
4 High Lock
4 High
Neutral
4 Low
4 Low Lock.
4 High
2 High
Neutral
4 Low
