No synthetic
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Hello,I have a 1980 Chevy C10 (my first vehicle) and the guy I bought it from started using mobil 1 synthetic and said its so thin it leaks some but I've been looking in to synthetic in an oldish engine and it's potentially harmful because it eats through grease and oil build up which may be good in new trucks but not oldish ones . So I guess what I'm asking is for more proof that synthetic may be a bad choice.
CRM
Pasco, Washington
Casey
K2500
350 CI
Found this on a Mechanics website:
Using synthetic oils in older models
When using the term “older” to refer to cars, it means those manufactured before 1990 or so. The risk with these models is that the seals and other components often aren’t as tight as with newer models. The synthetic oil could leak out and the vehicle could burn or lose oil. What this means for you is that you would be replacing your oil and having to monitor the levels more often. If you didn’t, you would risk damaging the engine or other components. Because synthetic oil does a better job of cleaning out sludge, it could remove deposits that are acting as seals.
It’s not accurate to say that you should never use a synthetic oil in an older car. If the car has been maintained and is in excellent running condition, the synthetic oil may protect the vehicle and prolong its life.
Signs of problems with synthetic oil in older cars
If you decide to switch to synthetic oil for your older car, talk to a professional mechanic first. He may want to check over your vehicle before advising you. If you make the switch to synthetic oil on your own, you will notice oil leaking out from the vehicle if there is a problem. You will need to have a mechanic look at it and make any necessary repairs or replacements. It's important to read the owner’s manual or talk to a mechanic about any changes you want to make with the type of oil you are using to protect your older model vehicle and ensure its long life and continued performance.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
I run Amsoil Z-Rod in my 454 with 149k miles on it. It does not smoke or consume oil, but it does drip from a very leaky oil pan gasket. But that would happen regardless. I like the Z-Rod, even though it is full synthetic, because it has the zinc in it. It's good for our old-school cams.
Iowan
Iowa
Calvin
K1500
350 crate
Thank you all very much. So if I switch to conventional will that hurt it? but again thanks.
Clewis
