No power at temp gauge
76burb
texas
matt
suburban k20
76 3/4 ton suburban. All gauges work except the temp gauge. Replaced the sending unit, gauge still won't move. When I ground the sensor wire the gauge pegs past full.
I pulled the gauge and used a multimeter to test the receptacles where the gauge plugs into the cluster. Driver side plug should be 12v key power and top should be ground. I get -.02 on my multimeter when I test those. When I test passenger post(sending unit) and ground I get 11.6v.
What do I need to do to get power to the gauge. The key was on when testing.
dd1990
Ventura CA
Suburban 1500
Sounds like wire going to senidng unit is cut or gauge cluster printed circuit is messed up. I would look up the temp wire on the 18 pin and see if you get any continuity
76burb
texas
matt
suburban k20
Sending unit wire seems to be good. What is the 18pin?
When I ground the sending unit wire to battery gauge pegs full. If I manually move the needle to the right and then turn the key on the needle goes back to cold.
If you ground it and it pegs,then your getting power,you are not getting a controlled ground. Check continuity on wires from sender to gauge and sender to head.
Check continuity from the sender terminal to head on the sender with wire disconnected. Check hot and cold see what readings if any you get.
Did you use Teflon tape on the sending unit threads? That can prevent getting a good ground to the head. Check resistance between the sending unit body and the engine and it should be zero.
76burb
texas
matt
suburban k20
Update-- I did find a small cut in the green wire. I replaced that section of wire and still have the same issue. Temp gauge stuck on cold. If I remove the gauge and move the needle to hot then replug the gauge back in it flips back to cold immediately. I have tried another gauge and that one does the same thing.
I also put my testers on both ends of my old sending unit while it was out of the block and got infinite resistance or the 1 on the far left of screen.
when I put the tester on the installed sending unit and then the other to the engine I got the same 1 on the far left side of the multimeter which I think means infinite resistance
gmbellew
Kansas city
glen
suburban 1500
infinite resistance means it is open and has no continuity, right? sounds like a bad sending unit?
Did you check either of them hot? Did you check continuity sender to head?
76burb
texas
matt
suburban k20
cold and out of the truck the sending unit tests about 600 ohms. I installed the sending unit and let the engine run for a bit to get hot and then tested the sending unit and grounded to a bolt on the ac bracket and got like 200ohms
Gauge still reads just above cold. tried a different used gauge and it reads the same. teflon tape removed from the new sender
I have also tested the resistors on the back of both gauges and they read roughly 85 and 95 ohms
Double check me but I think 74-78 cold reading should be 350 ohms. I'm thinking you have the wrong sender to the best of my knowledge there are 3 and all 3 are different resistance.
76burb
texas
matt
suburban k20
Ive got the sender with the round terminal that fits the Packard connector on the sender wire. I thought the later senders had a spade connector.
Resistance
Max Headroom
