No fuel
Bigdaddyjak
N. MI
Jamie
Key off, orange wire, 12v at relay, 12 at the block that goes thru the firewall and 12 at 10am ecmb fuse and 12 at tank. Still no feul at injectors, I can feel the feul line has pressure, it is hard. Can’t believe the filter could b that plugged ! I will pull it off next I guess
Bigdaddyjak
N. MI
Jamie
i Loosened the tank and lowered it a bit, I noticed 2 wires,(it’s hard to c anything at the topside of frame when tank is in) I had ounces them between the frame and the tank bracket . Repaired them, truck is running . Thanks for all the help guys !
ExtraZ
