No chassis electrical
raherres
Spokane
Ryan
V20
First post, so I apologize if this is wrong spot, or already answered. I have been 2 years into full body off resto of 87 v20 with T.B.I. 350. Everything that went back on was replaced with new or rebuilt. As many parts as available was AC Delco, everything else was researched for best option. Through this whole process I have found several answers to many problems or better ways to do things from this site, so thank all of you. My issue, that I tried to find a topic specfic to my biggest problem yet, is on the electrical side. Everything was finally ready to fire the engine for break-in, but when I trurned the key to on position volt, oil, and temp guages were obviously not working. I have all lights, turn signals, wipers, and 4WD indicator working, After going through here and a lot of googling most common solution was a ground. I have triple checked all grounds I am aware of, with no change in outcome. My next thought was fusible link, but I can’t find if there is more than one, or how to properly diagnos this. My cousin, who helped with the resto, is thinking ECM. I am really hoping someone has encountered something similar, or has a idea of where I should be looking.
Do you remember hooking up the instrument panel ground? Should be a black wire up under the dash, and on an ‘87 connected to a ground bus bar on the firewall up above your feet.
Also check to see the body is grounded to the engine (braided wire on the back passenger side of the engine) and the battery is grounded to the frame (wire from battery negative down to top of the frame near where a mechanical fuel pump would be).
raherres
Spokane
Ryan
V20
I will check again, but quite certain cluster is grounded. I do have lights, blinkers, and indicators working properly. I know the firewall ground is good and secure, but I will also double check that. And completely certain of batt to core support to engine to frame are all good.
Another possibility, since you have power to lights, but apparently no ignition-switched power.
During your restoration, did you remove or drop the steering column? The ignition key turns a small toothed rack, which pulls a rod running up and down the column, and the actual switch is connected to the rod and mounted near the point where the column goes through the dash. That toothed rack is made of pot metal, and subject to breaking or cracking.
If the rack on the end of the key cylinder breaks, the rod is not pulled up and down correctly and it does not properly actuate the switch as you turn the key. Also, if the switch was unplugged or removed during your work, it may need to be readjusted up or down so the electrical contacts line up correctly.
The ignition column and switch is a standard GM design, and is used on many vehicles. Lots of online documentation for repairs.
raherres
Spokane
Ryan
V20
Yes. The steering column was completely rebuilt as well. I will check on those ground points now that it is daylight.
raherres
Spokane
Ryan
V20
I believe that I have verified good grounds. I took a volt meter and have 12V at various points on motor, frame, and body to B+. Not saying this is ruled out, but I also put the old ECM back in with no change in results. I can not trust that old ECM was good.
Scott91370
Burleson, Tx
Scott
Sierra1500
Check the connection for the bulkhead on the firewall. Mine looked tight but I put a socket on it and it was not.
Log Dog
Hopkinton Ma
The moral of this story is to remember the first rule of troubleshooting anything: Check the easiest/cheapest things first! Do not assume anything or read ahead and jump to a conclusion. Just put all the tools away, clean up the shop, go back inside the house, grab your favorite beverage, grab a pencil and paper, sit in your favorite chair, and concentrate on what the easiest/cheapest thing is that I should check first and then, just like in every manual, if good, check next, if not good repair or replace. It's a very hard thing to do sometimes as emotion and frustration will drive you up a wall. It's taken me years and a huge amount of time wasted to remember to do this. Just like checking the grounds, which in many cases is the last thing to check after checking all the positive voltages. Remember, this is the the fun stuff and the reason why you started this project in the first place, have fun!
Thanks for the help. Ended up being the stupidest thing possible, but cheap fix. 10 amp IGN fuse.
No it's not just a fuse,fuses don't just get old and quit. If the fuse popped it popped for a reason,you need to find,what overloaded the circuit or it will fail again.
erikm00
