SilverJimmy
- Mar 12, 2011
- Seattle
- James
- c20 Silverado
Hey fellas, I need a little help wrapping up my carb swap. I have an Edelbrock 1406 going onto the q-jet manifold. I am using the square to spread bore adapter plate, and have replumbed the fuel line with in-line filter. So far so good...
Now I am stuck on the vaccuum and egr valve connections - I forgot to mark things as I pulled them - damn. Also, I am not sure where the PCV tubing goes from the front of the carb.
Lastly, is that my EGR valve coming from the manifold directly left (passenger side) of the carb? I've read that this needs to be blocked-off, but the block-off plates I see (triangular) dont match the size of the hole, which is square-ish.
Here are some pics of my pickup, albeit blurry, and a few of the engine without the carb/aircleaner. This was supposed to be a "weekend" project lol, and the wife wants the garage back.
Any help or advice on the emissions clean up would be most appreciated.
