Crispy
- Apr 5, 2017
- Carbon County, Pennsyltucky
- Chris
- Suburban V1500
3970010 is a very common casting number which unfortunately doesn't give you much info other than it was a 350 with 2 or 4 bolt mains used from 1969-1980 (or 1979 depending where you look). If that info is correct then its probably not the original engine to the truck. You would have to pull the pan to verify if its 2 bolt or 4 mains.
As for V0582100, I've got nothing, sorry.
