DuallyGuy
- Aug 17, 2012
- San Fernando Valley, California
- Matt
- GMC C15 1/2 Ton Stepside
- 5.7L 4BBL 350 V8
Ok...UPDATE: The funniest thing occurred...I checked the IAC and observed the small tip pop out into the passage. But only when the engine was turned on. Not with just the key turned on. So hopefully that means its working right? As for the TPS, I started the truck and then I unscrewed the TPS while it was connected to the harness. I began to play with the lever as the engine began to rev high and low. Well as I kept adjusting the lever on the TPS, I ended up finding a sweet spot where the motor idled just right. So I mounted the tps back to the throttle body and tightened it up gently to make sure I didn't lose that sweet idle spot. I put the air cleaner and all parts back on and took it for a spin. She's running great now. I dont know what happened or if it's just a temporary fix but the truck seems to be idling right. BUT...when i came home, I popped the hood and checked the voltage on the TPS...It was reading 1.15 still. I'm going to check it again. Maybe I checked it wrong, but as far as my motor, she's purring right now.
