New to me 86
TKyger
US
Tim
For $300 , and it's running , you can take your time a let the kinks appear on their own, Welcome to the site!
That's generally the plan, the carb is a little sticky and one of the gas tanks has rust holes, but I don't know which one yet, so I also don't know which tank it's pulling from. That and a rotted breakage pinned are my biggest concerns
Sent from my SM-N950U using Tapatalk
TKyger
US
Tim
How would I go about figuring out what size fuel tanks it has in which side, as well as had anyone had issues with the fuel tank switching valve?
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Rockauto tends to have the measurements and capacities for fuel tanks. Take the measurement of your tanks and compare.
TKyger
US
Tim
I was hoping to order one or both tanks before I get home in March
Crispy
Suburban V1500
Its a guess unless someone knows for a fact but I believe the smaller tank would go in a short bed.
SPECTRA PREMIUM/COOLING DEPOT GM11B {#14040786} Lock Ring Kit Included
42-7/8 In. x 14-1/8 In. x 11 In.; 16 Gallons Tank
SPECTRA PREMIUM/COOLING DEPOT GM1B {#12382992} Lock Ring Kit Included
56 in. x 14 in. x 11 in.; 20 Gallons Tank
TKyger
US
Tim
But having two fuel tanks, would one be bigger than the other?
hatzie
k20
I had a couple long beds with the smaller single tank. That being said... When I replaced em I got the larger tanks.
If the truck is a long bed and came to you with mismatched tanks it's conceivable the PO had one, of a pair of 16-gallon tanks, rust out and replaced it with a 20-gallon tank. There's no reason not to... Or they were a cheap ass and replaced a rotted out 20 with a 16...
IIRC the fuel tank frame supports will fit either tank... I don't recall buying new ones to replace serviceable old ones... The senders definitely fit either tank.
As far as the 305 goes. It's a lower power engine with no performance modification potential. If it runs well and doesn't smoke... it's free and it's much better than no engine.
TKyger
US
Tim
When I got the short bed I was told one tank has rust holes, but upon looking under the truck they're both pretty rusted and I can't tell which one is supposed to have the hole.
I also have no idea about the tank switching valve: which tank it's pulling from, if it works, is the switch works, or how to test the valves or the sending units.
Any idea of the oil gauge is electric or mechanical?
TKyger
US
Tim
I would think they are same on each side.
My ex had a 96 Ford that had a 28g and a 16g (or something like that) tank from the factory, I didn't know if Chevy might have done something similar
Howdy!
Shortbeds all have 16 gallon tanks, as the 20 gallon tank physically will not fit.
The furd had different sized tanks due to packaging. One tank ahead of the axle and one tank under the rear. They built and installed what would fit under the truck.
Also, there's been several threads here about diagnosing inop dual tanks, looking around a bit should provide a lot of info.
TKyger
US
Tim
Howdy!
That is exactly the answer I was looking for! I greatly appreciate it! As to the other threads: my apologies, I've been running like crazy and haven't made time to look yet but now that I know there out there I will definitely look.
Again, thanks! -T
77 K20
Montana
K20 5" lift
HT383 fuel injected
Welcome!
As far as a "weak" spot when you have the time check out the frame where your power steering bolts to. This area can crack. If it isn't cracked then there are support braces you can bolt in. Or there are braces you can weld in also.
The engine cross member can develop cracks... and the upper rear shock mounts can crack also...
Seem to have crack on the mind this morning. :boxed:
hatzie
k20
goodwrenchca
