86 C10 Shortbed
- Jul 19, 2016
- Ohio
- Mark
- C10
- 5.3L
Welcome from Central Ohio
Look for the SPID in the glovebox.I don’t have the truck yet, but as soon as I get it, I’ll post some pics.
I have an f250 I’ve been pulling my rig with, so I’m fine there, just thought it’d be cool to pull up with my rock climbing cj7. I’m sure now, I’ll keep it somewhat original, keeping the 350. I’ll probably put a fuel injection system on it though.
Is there anywhere I can put in the vin and tell what the original equipment was?
Shape of the pan on the trans will tell you which transmission. Most likely it has a th400. Although, an 85 k20 burb I looked at came with a 700r4. The transfer case will either be steel (205) or aluminum (208). There may still be a data tag on it.I’m not sure what transmission or transfer case is in it. It’ll be a couple of weeks before I see it again. So crawling under the truck, how do I tell which trans and transfer case is in it?
You can find several different transmission pan shape identifying diagrams with a quick internet search.Shape of the pan on the trans will tell you which transmission. Most likely it has a th400. Although, an 85 k20 burb I looked at came with a 700r4. The transfer case will either be steel (205) or aluminum (208). There may still be a data tag on it.
