New Guy from Wa. State
jkien88
Washington
v10
Hey there, new to the site.
I own a 1988 Suburban 1/2 ton. Family man with 6 kids and 3 dogs. Looking forward to checking things out and figuring out what's wrong with my truck.
Stroked
Beloit, Kansas
Jared
Welcome from Kansas!
Covington, WA
350; 700R4
Welcome from Kent, WA!
:welcome:
bigcountryguy19
Sealy texas
josh
6.2 diesel
:cheers:Welcome, glad to have you aboard
:welcome: from N.E. Texas!
Howdy! Finally there's another member here that also has a bunch of kids! I don't have any dogs though, just 1 cat and 8 chickens.
1ATony
Tony
K1500
Welcome to the site.
Tony
jkien88
Washington
v10
Thanks guys. Can someone direct me to where I can look up Ob1 codes?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Thanks to Jim.
Trouble Code
SYSTEM
Indicating
12 Diagnostic Checking for operation of CEL bulb
13 Oxygen Sensor Circuit No signal to computer
14 Coolant Sensor Circuit Excessive HIGH temperature indicated
15 Coolant Sensor Circuit Excessive Low temperature indicated
16 VSS - Vehicle Speed Sensor Signal Loss
21 TPS - Throttle Position Switch High Signal Voltage
22 TPS Low Signal Voltage
24 VSS Set when in motion only - disregard if set in park
32 EGR EGR system failure
33 MAP - manifold absolute pressure sensor MAP sensor voltage high
34 MAP MAP sensor voltage low
35 IAC - Idle Air Control Motor Idle speed above/below desired idle speed
36 Idle Speed Control Actuator Open or Short Circuit
42 Ignition Control open/short/component failure
43 ESC - electronic spark control ESC module not receiving knock sensor signal
44 Lean Exhaust Low oxygen sensor voltage
45 Rich Exhaust High oxygen sensor voltage
51 PROM (Memcal) Faulty computer chip
53 System voltage high Carging System is over 17.1 volts
54 Fuel pump relay Low voltage / short
55 ECM Computer (ECM) failure
Sticky found here: http://www.gmsquarebody.com/forum/showthread.php?t=6844
83GMCK2500
Ellensburg, WA through Poulsbo, WA through Pullman
Devin
K2500
Welcome from Ellensburg.
I HIGHLY recommend the GM Service/Diagnostic manuals for Fuel/Emissions systems. They are super useful for the TBI engines. You can find them on eBay, look for the R/V-Series ones.
sam s
