TX87R10
- Jun 25, 2020
- Texas
- Txr10
- R10
I finally got my spring seated in the top pocket and the bottom on the LCA.
I was so happy I started jacking my truck up, put the spindle back on, jacked it up more to connect the upper......
And then I realized the spring is so strong right now it's picking the truck up off of the jackstands. Even if I were able to reposition the jack and get the top connected I feel like it would be constantly under extreme force.
Did I get the wrong coil spring? Moog 6452 from summit. It stands the same height and has same diameter of the spring itself.
I really need to finish this project up but I don't want to put the worn out spring back in there :/
