Need wiring diagram for accessory position on ignition key switch
73c20jim
Tombstone, AZ
I need to know what circuits are activated when the key is turned to accessory position. Are all the contacts for accessory inside the ignition switch?
GM wire code numbers and/or wire colors will be greatly appreciated.
I believe the colors and usage are:
Plug 1 (my number) 5 contacts
Pink >>>>>>>>>>>>> coil
Purple-white >>>>>>>> starter
Red >>>>>>>>>>>>> always 12V +
Brown >>>>>>>>>>> windshield washer
one slot empty
Plug 2 (again my number) 4 contacts
Black-tan >>>>>>>>>> brake warning light / brake warning light switch
Dark green >>>>>>>>> temperature switch / gauge panel
Orange >>>>>>>>>>> Connected to brown / heater switch
Brown >>>>>>>>>>>> connected to orange / alternator
Red >>>>>>>>>>> >> always 12V +
Any help is appreciated
Thanks
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Looks like the wipers and radio are on the brown accessory wire.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
i believe this same switch was used on most of our trucks. hope it helps. looks like pin 4 is all acc.
DanMcG
Central NY
k10 k10
I think this might help, but I guess I'm not exactly sure what you're looking for.
73c20jim
Tombstone, AZ
That's exactly what I needed.
Thanks.
73c20jim
Tombstone, AZ
Thanks
73c20jim
Tombstone, AZ
73c20jim
Tombstone, AZ
You guys are the best.
73c20jim
Tombstone, AZ
Got my **** figured out. Have intellitronix gauges and instructions say to put key in ACC to setup gauges. Turn to IGN to get out of setup.
Problem is the is NO ACC wire on the gauges. Ergo no power. Turn to ACC and gauges are dead.
Gotta call these guys again and have them explain how this works.
ACC powers wipers and radio and whatever else you hook to the circuit.
zapattack
